I once saw a guy use a bolt on a vertical pipe with differnt wall thicknesses. He put the put the pipe in the clamp and welded a bolt in the gap. Took the pipeclamp off and cut the top and bottom with an oki beveler. On the bottom was hooked up too a strap and excavator. Some shop tests here do this too see what you do know. Over most companies that deal with pipe here also deal with the refineries.
robert
