set it up just like you were welding steel only expect that the stainless will take more heat to melt, about 1000 degrees, and your gas should be at about 35 psi. Stainless mig is just as spattery as mild mig. It really isnt much different when you get down to it. Just takes more heat. And the polarity changes when you go from mild to ss.
