Up Topic Welders and Inspectors / Welding Equipment Classifieds / remote for pipe pro 304
- - By weaver (***) Date 06-02-2008 03:06
hey guys im looking for a remote for a pipepro 304, drop a line thanks...
Parent - - By Justin O (**) Date 06-10-2008 04:46
I bought one that looks just like a lincoln remote with the built in plug and 125' lead let me know if you want the number.
Parent - - By sbcmweb (****) Date 06-10-2008 12:55
Got that number? How much? Thanks. S.W.
"Whip it, whip it good." ( Whip it, Devo, Freedom Of Choice LP.)
Parent - By psyco33 (**) Date 06-10-2008 13:34
hey this is psyco33 i build those boxes out of stainless or aluminum your choice.
918 728 7079
Parent - By weaver (***) Date 06-10-2008 17:42
yeah man sounds great, you run a pipepro right?
Parent - - By tighand430 (***) Date 06-10-2008 15:49
The pipe pro takes the 14 pin remote if I remember correctly. Miller only has one remote they make that I know of. Miller PN#:129340. Miller says it costs $239.00.
Parent - - By JHarlos (**) Date 06-10-2008 23:14
The outlet is 14 pins, but the remote itself is only 3 pins. can find out which 3 in the book.
Parent - By sbcmweb (****) Date 06-11-2008 12:17
The 14 pin plug will have this configuration: The two contactor wires, black & white will go to pins A & B respectively. If you only have the 3 remote wires, they will go: Brown, green, red (min/max, brush) C, E, D respectively. This is for the RHCS 14 Miller control. Hope this helps. S.W.
