Hi Al!
So you got one of the supercharged "XPS" series Dell laptops???
That's one heck of "Puter" there pal!!! I've got one of those Lennovo Thinkpad R61I's that's one color... BLACK!!! However, I'm starting to think that these laptops are being monitored by the Chinese government because of all of those so-called updates!!! Maybe I should wrap some aluminum foil around it so they can't hack my "Puter" :) :) :)
Look at the schematic of the Dell, and see where the LED's are connected to see if they can be easily disconnected... Who knows, it just might work!!! ;)
Anywho, I remember back in the early eighties, an MG salesman wanted to impress us by showing us a so-called trick by dumping a few 1/8" dia. E6011 electrodes inot a bucket of water... He then asked to turn this 300 amp CC power source to maximum output, and then proceeded to make some really rough cutting with the aforementioned electrodes, and then started to attempt to gouge on the 1/2 " thick plate he was using to demonstrate which produced similar results...
Then in an attempt to razzle and dazzle us even further, he pulled out some of MG's own brand of SMAW cutting & gouging electrodes which worked much better than the E-6011's he first used... So I asked him why his rods worked better, and he responded by explaining that the chemical contents were of a proprietary nature so, he could not tell me!!! I asked him "How much??? He said "Ten bucks a pound!!!" I replied: "Get Bent!!!" "No really, if you have to ask how muhc then, you really don't need it that bad!!!" "Yeah - okay - DUDE!!!" was my response... ;)
After he left, I decided to do some of my own experimenting, and found that if the rods were to be soaked for one hour in the water, they would work almost identical to the MG fancy - dancy rods that this hot-shot salesman was trying to push on us at this welding distributor I was working with many moons ago...
Six months later, this Hot - Shot salesman decides to visit hte area again so, he stops by our distributor again to see if we were pushing those fancy - dancy rods for his company... When he asked me how it was going, I responded by asking him a question: "How much do you guys charge for the water preparation done to these rods??" because by then, I had achieved identical results with regular Lincoln E-6011 electrodes as his company's proprietary brand of cutting & gouging electrodes, and wanted to see his response to my question.... The conversation quickly turned towards another one of his company's brand of electrodes which would weld stainless to mild steel...:) :) :)
That's when I knew this guy was nothing more than a "Snake Oil salesman" and could not be trusted at all!!!;) Btw, your explanation really hits the nail right on the head with respect to the sodium silicate!!! So thanks for sharing the design of your refrigerator system... I've seen a few of them used in similar setups in a variety of locations in the tri-state area of NYC yet, I don't remember if they were setup like how you describe your system which makes a whole bunch of sense!!! :) :) :)
Yeppers!!! A dry, and heated 5P rod will not work so well in a pinch when it comes to welding with them but, you can dunk them in water for about an hour and a half, and Voila!!!
Gouging rods without the air!!!
That is, so long as you crank up a 300 amp machine to it's maximum output because if you've got a 200 amp machine - you're Manure out of luck!!! :) :) :)
