Wayne,
Nobody should give you answers for the CWI exam... Here or any other place.. ever.
If you want help to study you will find this forum a rich place with some of the top experts in the field.
If you use the search function on this forum and type in "CWI exam" you will find hours of study material, links and valuable study and preparation stratigies.
If your just looking for questions and answers you better batten down your hatches and be ready for some rough seas.
waynebhayes,
Lawrence has said it quite nicely. Also, even if you were to get someone who has recently tested to give you questions and answers, these would almost assuredly not do you much good. AWS has a question bank of enormous size. NO two tests are the same. For example, lets say I tested and failed, and I study the questions on that test and have all the answers memorized (not likely) so that I can test again and pass. NOT gonna happen. Your next test will NOT be the same questions. It will not even be the same questions in a differant order. If I am not mistaken, the test questions for each individual test are compiled randomly by computer from this "enormous" bank of questions, this means that even the guy sitting next to you on test day has differant questions than you will.
My advice is to do just as Lawrence has suggested. Many, if not all on this forum will help you with study recommendations, habits, and advice.
Good luck,
jrw159
