I have been looking but the only thing I have found is a Tweco Eliminator 300 amp #ESG225-3545 with a Tweco control box #ESG-1. I called Tweco and a tech person there E Mailed me that he "thinks" this gun and box will work on my MM 200. I would have thought that he could have come up with more then "He Thinks" it will work. I sure don't want to spend that much on a I think it will work ! ! ! How much should I spend on this set up?? Can any of you folks give me an idea on this gun and box working on my 200? I will need to know ASAP this equipment may not be for sale long. Thanks for your help.
Have fun,
Allen
By sbcmweb
Date 06-15-2008 02:57
Edited 06-15-2008 12:24
Allen. Don't waste your money on something that's not made for your machine. I stated in the last post what a spool gun for your machine is worth. Unless he's giving the Tweco away, I would just hold out until you can find a #1 for your machine. The Tweco unit is probably very overpriced & you'll have to hack to make it work. Just keep looking on ebay, you'll find a #1, I'm sure. They're common. Good luck. Steve.
Steve is right, You will have to figure out how to wire the control box to Your machine's contactor & power, not extremely dificult, but not a "plug & play" situation. I have been keeping a pretty close eye on eBay for about 2 years, and I havn't seen one of these Tweco units come up yet, and have not seen one in person. It might be a good unit, just not real common.
Dave,
I will take what you and Steve are saying as sound advice and hold off for the spoolmatic 1. If you guys are interested the Tweco unit I was referring to in now listed on E-Bay under "spool gun" I sure do appreciate you folks responding to my questions. It is going to save me a bunch of money and head ache. Thanks again.
Allen
Does anyone know if a Miller Spoolmate 185 will work on a Millermatic 200? If so, I do have one for sale. It was labeled "Spoolmate 185 " and it came packaged with the Millermatic 185 when the 185 first came out.
Allen, I saw the gun you are looking at on ebay. It will probably go outta sight. Just keep looking for a #1. Do a check under spoolmatic, spoolgun & spool gun. I'm positive you'll come across one. Just keep looking for it. S.W.
What was it listed under? I just checked each of those three spellings for it. It must be gone already. In the past all I was looking under was "spool gun" I didn't think it made a difference in how you spelled the item. Thanks for pointing this out. After your post I went in and entered each spelling and found out how many more items show up!
I put tweco Spool gun. I wouldn't waste my time on that though. Just go under the names I mentioned in the prior post. I'm sure you will find one. I sent you a PM as well. S.W.
By dank11
Date 06-20-2008 21:33
Hey!
I've got a MM200
had the spoolmatic 1 for It (sold it sorry) Didn't really like It
Big and Awkward
ended up hooking a Cobramatic prince XL gun to it (could be used on any CV power supply )
You would have to buy a gun and controller
and need 115 volts
I do have a Cobramatic MK-3a that will plug into anthing also But set up for the MM 200
was trying to get $700 + shipping
Thanks!
