Up Topic Welding Industry / Technical Discussions / Welding Operator
- - By Rick Hoople (*) Date 07-18-2008 04:11
Quick question,
If a welder is qualified to the semi-auto FCAW process, is he qualified to an automatic weld process where he becomes a welding operator? My question stems from a situation where we have welders qualified to The FCAW process, but need them to do automatic seam welding, does their in house cert cover them for that?
Parent - - By motgar (**) Date 07-18-2008 14:39
Rick,
Not sure if the welders are qualified to AWS D1.1 but,
Welders qualified for SAW, GMAW, FCAW, GTAW shall be considered as qualified welding operators in the same process(es) and subject to the welder essential variable limitations.
AWS D1.1:2006, page 150, Table 4.12 sub note b.
Parent - - By Rick Hoople (*) Date 07-18-2008 21:15
So, a welder who is qualified to the FCAW process, is also qualified to an automatic FCAW process?
Parent - By motgar (**) Date 07-21-2008 12:44
I see it this way.  If the welder can perform semi-automatic FCAW, then he or she should be able to apply those skills to the automatic FCAW process.
It may require some additional training to familiarize them to the controls but, that is not a variable.
Parent - By RonG (****) Date 07-18-2008 17:39
Process is an Essential Variable.
