Up Topic Welding Industry / Technical Discussions / Limitation of GMAW for plate thickness
- - By hamedian Date 09-02-2008 09:13
Dear All,
We are a manufacture of cement factories equipment. In our shop we use GMAW (by Co2 gas) method for welding of plates with ST37-2 material. Thicknesses are between 3 to 100 mm.
My question:
Is there any limitation for using GMAW method in all thicknesses of plate?
Our supervisor/inspector tells us to use GMAW only for plate with thickness under 8 mm.
Thank you in advance for your technical information.
Yours faithfully,
Parent - By aevald (*****) Date 09-02-2008 09:52 Edited 09-02-2008 10:07
Hello hamedian, I certainly wouldn't say that you can't weld the thicker sections with the GMAW process, however the use of Co2 as a shielding gas would definitely not be my first choice. I have only used GMAW with Co2 for a structural application one time and the weld deposits definitely weren't pretty, in order to make the proper beads the voltages had to be high enough that they resulted in operating the process in the globular transfer mode. If you are dead set on using GMAW you may want to consider using an 85Ar/15Co2, 90Ar/10Co2, or some form of mixed gas with at least an 80% or higher level of Argon. This will allow you to operate in a spray-transfer mode and likely have much better looking weld deposits and less weld spatter and bead clean-up issues.
     Is there reason that you don't want to use a gas-shielded FCAW process for the heavier sections? If you are wanting to stick with the Co2 gas selection there are a number of very clean-running FCAW gas-shielded wires that would certainly meet your needs and make spatter and clean-up issues minimal. A few items for you to consider, likely others will chime in here with their additional suggestions. Best regards, aevald
Edit: I should add however, that if you change some of these variables it may require the re-qualification of your welders or procedures if you are working to any specific codes.
Parent - - By Stephan (***) Date 09-02-2008 17:59
hamedian,
as aevald has already assumed by the end of his excellent explanations, please let me step in here.
As I saw that you have used the old designation "St 37-2" which comes from the former German standard "DIN 17100" (Allgemeine Baustähle ~ Plain Structural Steels) I had the vague idea if you were eventually working according the European Standards (EURONORM = EN).
Resuming please allow to let me first of all "correct" the steel designation, where "St 37-2" was changed into "S 235 JR" and standardized within the DIN EN 10025.
As presuming your work is according to the EN Standards, and the parts you are manufacturing are complying with a WPS before they produced, let me assume that you are choosing your filler materials in accordance to DIN EN 14532 "Welding consumables - Test methods and quality requirements - Part 2: Supplementary methods and conformity assessment of consumables for steel, nickel and nickel alloys".
But, and this is tricky, I guess you will have to accomplish your Welding Procedure Specification in accordance to the DIN EN ISO 15614 "Specification and qualification of welding procedures for metallic materials - Welding procedure test".
Hmmm... and now it gets completely complicated in general.
The first named standard namely (DIN EN 14532) restricts the Gas Shielded Metal Arc Welding (GMAW) under using solid wire electrodes in case of welding butt joints by stating a maximum part wall thickness of 50 mm (~ 2").
The latter standard however (DIN EN ISO 15614) contains none of a restriction in both welding process (GMAW) and part's maximum wall thickness(!).
Where, you may ask, does this confusion come from.
To go not too much in detail. The restrictions within the EN 14532 are based upon the TÜV pressure vessel codes and here in particular upon the TÜV Data Sheet VdTÜV 1153. As this code has been created several large classification societies have cooperated with its generation (amongst the TÜV itself e.g. CONTROLAS and FORCE). Thus it has been decided - since 1988 - to limit the maximum wall thickness by 50 mm when using the GMAW (solid wire electrode) and welding a butt joint with pressure vessel components. The restriction in regard to the wall thickness was based thus upon the higher requirements in the welding of pressure parts. However, as well in this field of welding it was possible for the manufacturers to prove their capability to weld pressure part butt joints above 50 mm wall thickness - even by accomplishing and passing a Welding Procedure Test. And the major concern of all of this was the fear to getting lack of fusion inhomogeneities when GMAW of wall thicknesses > 50 mm.
However, due to the meanwhile certain knowledge of how it's feasible to avoid lack of fusion also with larger wall thickness parts both fillet- and butt weld, there is definitely no restriction or limitation - at least according to the European Standards - within the field of structural steelwork for the part's wall thickness in combination with GMA solid wire electrode welding. So I would venture to "refute" the statement coming from your supervisor - at least as it belongs to the valid standards and as long it would treat the "magic" 50 mm limit. What I actually not know however, is the fact what kind of requirements your employer wants to have being met by you. If your employer demands even a restriction of the maximum wall thickness with the parts to be GMA welded, by whatsoever the reasons were for this decision this should matter as a fact to be complied. Even though it were actually unnecessary according to the European Standards. However, I have honestly never heard before of a wall thickness limitation by 8(!) mm when using the GMAW both with solid or flux cored wire.
And if I am allowed to say so. This would make absolutely no sense, since it would destroy all the specific economical process benefits in general.
As a little recommendation let me say finally what follows.
In terms of product liability you should be recommended to ask your wire electrode supplier if their wire electrode would fit with the WPS requirements when using it for wall thicknesses > 50 mm. But this however, should only be an advice as long as the wire's data sheet shows no clear statement concerning this question.
Best regards,
Stephan
Parent - By 803056 (*****) Date 09-03-2008 14:08
Excellent responses gentlemen.
I would add that since the work is being performed in a shop, I assume the parts can be positioned so the welds are in the flat position for best productivity. That being the case, I would suggest using SG-AO-2%, i.e., 98% Argon and 2% Oxygen as the shielding gas and use the spray mode of transfer. Thicknesses over 3/16 inch are good candidates for spray mode transfer if welding grooves in the flat position and fillets in either the flat or horizontal positions.
The 8 mm thickness limitation is reasonable if you are using the short circuiting mode of transfer, which as already mentioned, are prone to fusion type defects. S.C. transfer allows the welder to weld in all positions, but if that is the case, FCAW would offer distinct advantages over GMAW.
Parent - - By hamedian Date 09-08-2008 14:06
Thank you very much for the fruitful information,
Is there any limitation in ASME or AWS standards (or other welding standard) regarding thickness range for application of GMAW?
Best regards,
Parent - - By 3.2 Inspector (***) Date 09-08-2008 14:13
hamedian,
I dont mean to be rude, but may I suggest that you or your company buy the relevant standards and codes.
Read the sections which apply to what you are doing, and then come and ask in case you have doubts - you will benefit more in that way.
3.2
Parent - - By pipewelder_1999 (****) Date 09-08-2008 16:14
Just to add to 3.2 inspoectors comments. YES there are restrictions. Both in ASME, AWS D1.1 and other codes. Each code will have the restrictions that apply. Your limit will be based upon the thickness the procedure is qualified for. That range will be dependent upon the code.
What codes do you have and maybe we can help get you to some information that may help you better understand this topic for your application.
Parent - - By hamedian Date 09-11-2008 14:03
Dear 3.2 inspector,
Thanks for your advice.
All mentioned standards are in access for me. I read but I couldn't find any restriction regarding thickness for GMAW. If you find it kindly inform me.
All libraries are full of books and students come there to study but they go to university too for better understanding. They ask their questions of teachers or specialists.
Dear pipewelder_1999,
Thanks for your reply.
You wrote:
"YES there are restrictions. Both in ASME, AWS D1.1 and other codes"
I know every method has restrictions for application but I want to know the restriction of GMAW method regarding thickness range of plate as Mr. Stephan clearly explained above in DIN standard.
I got a PQR for thickness 50mm and it was ok but our project supervisor says "GMAW method is restricted less than 8mm thk. If you decide to weld a plate with thickness more than 8mm you must use another method such as SMAW or you can weld root pass with SMAW and continue by GMAW", is this word correct acc. to ASME or AWS?
Best regards,
Parent - By HgTX (***) Date 09-11-2008 17:28
Ask the project supervisor to give you a code reference for these restrictions.  Unless you're using GMAW-S (short circuit), for which there are various restrictions, there is no particular restriction on GMAW in AWS D1.1.  What transfer mode are you using?  Even for GMAW-S, though, the D1.1 restrictions are qualification restrictions, not thickness restrictions, and it sounds like you've met the qualification requirements if you passed the tests on the PQR.  That said, I wouldn't recommend GMAW-S on thick material.  Other GMAW modes I would think would be ok, though the only GMAW I've seen in person has been with cored wire.
Hg
Parent - By pipewelder_1999 (****) Date 09-12-2008 14:19
ASME Sec IX or AWS D1.1 do not restrict the thickness you can weld with GMAW provided the procedure is qualified. It is possible I am not understanding your question. I have NO idea what other standards say.
