>The variable is the quality of the gouge. Its my experience that when I carbon arc gouge a weld from the back side, when its viisually clean, it passes MT/PT.
>I would submit that if you've found due concern for using MT/PT on backgouges you might wanna consider the more effective means of questioning the abilities of your welders and gougers.
