Up Topic Welding Industry / General Welding Discussion / miller elite auto hood
- - By and4rik (**) Date 10-15-2008 01:51
I like this hood for certain things but don't use it very often.  well, I pulled it out of my trunk to dust of and it seems as if the summer heat has gotten to it.  The side has warped in, it is still usable but i would like to try and fix it. Nothing is wrong with the lens:)
Anyways, any thoughts on how to fix this would be great.  I am considering taking a torch to it and remolding the plastic.  It doesn't have to be perfect just so it doesn't rub my cheek all the time. btw it's the cammo screen print model.  thanks
Parent - - By sbcmweb (****) Date 10-15-2008 02:41
Try using a heat gun. Much more control over the heat, with no flame to burn it up. Just don't go crazy with it. If you don't have one, Harbor Freight has them for less than $20.
Good luck. S.W.
Parent - - By 522029 (***) Date 10-15-2008 16:19
Also, the wife's hair blow drier would work but it might be a little dangerous if he got caught!!
Griff
Parent - By sbcmweb (****) Date 10-15-2008 17:16
Parent - - By bbwinc (**) Date 10-15-2008 03:00
Try the kichen oven, not shure of the temp or bake time but maby u could get it to a flexible state ,shape it how u want then run cold water over it. Or could be a bad idea, but just a thought
Parent - - By and4rik (**) Date 10-15-2008 03:02
hey, if it works mabey i'll make a video and post it on the forum!
Parent - By and4rik (**) Date 10-15-2008 03:03
oh, wait now its dvd
Parent - - By jrw159 (*****) Date 10-15-2008 12:13
and4rik,
  First try setting it out in the sun in a "relaxed" state, possibly hanging up. It should form back to its original shape. If this does not work use a heat gun as suggested, but don't get to close to it and take your time, it should work fine.
jrw159
Parent - - By Lawrence (*****) Date 10-15-2008 12:50
PS:
Remove the sensor unit before applying external heat!
Also.. a replacement shell for the thing might be as cheap as the heat gun..... Its the sensor/autodark guts to the things that make them spendy.
Parent - By jrw159 (*****) Date 10-15-2008 13:08
Lawrence,
   Very good points!!! :-)
jrw159
Parent - By and4rik (**) Date 10-16-2008 00:06
"spendy" :)
