Up Topic Welding Industry / General Welding Discussion / 1%, 1.5%, 2% Lanthanated???
- - By ndav8r Date 10-23-2008 14:44
Hi Gang:
I have been doing some limited tig welding with my Dynasty 200 on varies materials, mild steel, stainless, and aluminum with Pure and 2% thoriated electrodes. Now in the safety aspects in the grinding process, as well as the welding, I want to try Lanthanated.
Now I learned there are 3 choices...1%
Black, 1.5% Gold, and 2% Blue, Lanthanated.
Does anyone know the differences or applications for the differences?
Thanks,
NDAV8R
__________________
NDAV8R
Commercial Pilot since 1975
Lincoln SP 270
Miller Dynasty 200 DX Tig
Miller 252 Mig with Spool Gun
Hypertherm 625 Plazma Cutter
Bridgeport Milling Machine
Clausing 10 x 24 Turning Lathe
Two 1918 16 x 60 South Bend Turning Lathes
Parent - - By Lawrence (*****) Date 10-23-2008 15:45
For the purposes of manual GTAW in a limited environment... I don't think you will be able to see much difference.
Loose the pure tungsten... It will not perform properly with your inverter based Miller Dynasty.
My preference for all around is the lanthana 1.5  It performs well with DC and AC for aluminum.
Try a search here on the forum with key words like Lanthanum, and Ceriated/Cerium... There has been lots of discussion.
Parent - By TozziWelding (**) Date 10-23-2008 22:55
I just started using the 1.5% ones with an older Syncrowave 250, they take heat quite well, and hold a good arc on aluminum.
Parent - - By Kix (****) Date 10-23-2008 23:21
yeah 2% ceriated is my flavor of choice for everything!
Parent - By vagabond (***) Date 10-24-2008 01:26
Most if not all of the tungsten manufacturers give a good breakdown of the proper applications on the websites.  They have ez tables,  I usually refer to these for my welders.  Sometimes it will be on paper somewhere,  but I find more often it's not.
