Up Topic Welding Industry / General Welding Discussion / constant current or constant voltage
- - By cyrus 07 (**) Date 11-07-2008 19:10
Hi guys I guess this is a begginer question but whats the difference in these two also I have a 1972 lincoln sae 300 what one would that be??? thanks for any input..
Parent - - By K.Sexton26 (**) Date 11-07-2008 19:50
it is a constant current machine
Parent - - By JTMcC (***) Date 11-07-2008 20:00
You can add what Lincoln calls a "wire feed module" and then have either CC or CV output from that machine. A lot of those have already had one installed.
Short answer is:
CC is commonly used for stick and tig welding.
CV is commonly used for wire proccess' like mig, flux core, dual shield.
JTMcC.
Parent - By js55 (*****) Date 11-07-2008 20:54
Also, I think if you do a forum search on CC CV you'll find a wealth of threads on this topic.
Parent - - By motgar (**) Date 11-10-2008 19:40
Cyrus,
Here is some information about SAE 300 and SAE 400 Models S-7065 and S-7066.
http://content.lincolnelectric.com//pdfs/products/navigator/im/IM125.pdf
Here is some information about "constant current" and "constant voltage"
Attachment: PowerSources.pdf (278k)
Parent - By cyrus 07 (**) Date 11-11-2008 21:13
thanks for the replys fellas and I did a search afterwards and found more answers and motgar thanks for the cool download alot of info I can use..
