Up Topic Welding Industry / Welding Fundamentals / Tail lights
- - By Sberry (***) Date 11-18-2008 18:13
Everyone has problems with this, various way to protect light connections. I rarely use shrink wrap, have been known to silicone wire nuts but usually don't even do that anymore. I don't even bother sealing the boxes 100% weather tight. I usually use wire nuts, orient them so they are sitting upright, take the straw with penetrating spray and shoot a little in them after the connection and spray the inside of the box before closing. We use common steel boxes, 1/2 rolled poly will slip thru a 3/4 romex connector, makes shoving wires easy. You can take an awl and puncture it to insert a single wire if needed, for marker lite or LP lite, etc. The box keeps the studs from the fixture enclosed also. First pics are example, many variations of this theme.
Parent - - By sbcmweb (****) Date 11-19-2008 02:07
I didn't know you are from Michigan! Where are you at? (I noticed the plate on the truck) S.W.
Parent - - By Sberry (***) Date 11-19-2008 15:55
I am in Manistee County about 20 miles inland. Northwest lower.   http://www.urkafarms.com/
Parent - By sbcmweb (****) Date 11-19-2008 15:59
Cool!! Always nice to find someone from around here! S.W.
