Hello Dennis, "Ellis" also makes a pretty decent unit as well as "Wilton Square Wheel". So check them all out and see which one will fit your needs best. The nice thing about the Ellis is that the motor is at the back of the machine and allows really good access to the grinding portion of the front of the machine. The particular Wilton unit that I was referring to has three different diameters of wheels to allow for some flexibility regarding grinding radius, if that is an issue for you. One other consideration is belt selection, I prefer the blue belts, they tend to last considerably longer than many of the others. Best regards, Allan
