There are several pieces of literature available from AWS that addresses the visual aspects of weld inspection and discontinuities. You might take a look at the two guides available from AWS. Guide to NDT of Welds (B1.10) and Guide to Visual Inspection of Welds (B1.11) would be a good starting point. Both guides are in the process of being revised.
You should be able to borrow them from your AWS Section library if you are an AWS member.
