Hey Josh
355 ipm is very high for short circuiting transfer... That's a lot of current for 18 volts.
I guess first off, Have you asked Miller about this? High speed tip issues were a problem for Axcess models about 3 years ago... Word on the street was that many of these were solved... So if your power supply is not brand new,,, Miller should be your first place to go for advice..
I'm wondering why your using a $12,000 power supply to make short circiting welds that could be accomplished with a $2,500 dollar unit... Or conversely why not try RMD, which your Axcess was especially designed for, and produces much more controllable pulsed, short circuiting type output.
If the wire is fusing at the tip it is prolly better to look at the ramp up and down parameters in your termination sequence rather than your arc start sequence. So maybe you could tell us a bit more about that.
Josh,
Could be liner or feeder problems. I ran an Invision 354? on 304 and 316 SS with 316L .045 wire. I used GMAW-P and not short circuit. I would have similar problems when I used the wrong nozzle. We used a short nozzle where the tip would stick out just past the nozzle mouth for carbon steel and a long nozzle where the tip was recessed about 1/4-3/8 for the SS. If I forgot to change the nozzle when we changed over, it would weld like dog sh**.
Just my 2 cents.
