It takes two weeks to get the results. I took my test the 13th, and got the results back today. Good news, I passed!
I don't believe you can check on the web site for your test results. You can check your status after you pass by entering your number in the Certification check area. This will tell anybody who checks that you are active or not.
When you get the results, they tell you how you did for each test. They break it down into question areas, and tell you how many you got wrong for each test area. Well done, I like that they do that.
Good luck with your results.
