Well, for one thing, they break all the time whether you build them or buy them. All you gotta do is hit a rock or a stray piece of steel or a stump or something. The operator can feel the drum vibrating because it's out of balance and he knows it's time to change a cutter. This thing is used to clear large areas of brush like under major powerlines etc. Not the type of thing you'd use in populated areas. Anyway most anything I weld could break and cause an injury. It's the same for all of us....isn't it?
Don't take offence, Dave, but if you look at the subject of my original post you'll see that I was asking about the effects of heat on the hardened plate with regard to keeping the cutter reasonably sharp. So many times I read a post that goes this way and that. It winds up so far from the original posters concern that he/she must be wondering just how they got here from there.
But to answer your question, I'm not worried about my butt at all. I've welded hardened plate to T1 and mild steel so many times that wound up in extreme conditions (Excavator buckets for eg.) that I'm just not worried about it. When I get done it would take a force that would break anything to break these cutters.
