Up Topic Welding Industry / General Welding Discussion / Need some input on sa200 questions please
- - By Joe Davidson (**) Date 02-12-2009 03:37
[deleted]
Parent - By Marsh Welding (**) Date 02-12-2009 03:52
might get a better response if you put this down below in the sa 200 section. never had a machine with that trouble. pull your cap off the exciter watch the exciter spin with the machine running, if your exciter shaft is bent you should be able to see the wobble
