Up Topic Welding Industry / Technical Discussions / Few Questions
- - By sazid98 (*) Date 02-23-2009 18:31 Edited 02-23-2009 19:08
Hi,
I have some questions and i am trying to find out some reliable source for answering those questions.
1. what is the formula for calculating spot size in conduction/fushion laser welding?
2. when should you use filler wire in laser welding?
3. In case of conduction mode laser welding of a But joint what is the minimum penetration it should have to meet the AWS standard?
I will be waiting to listen from the forum members.
thank you
regards
Sazid
Parent - By hogan (****) Date 02-23-2009 19:28
would this be a class assignment for you to research and learn on your own?
