Up Topic American Welding Society Services / Technical Standards & Publications / D1.5 Filler Metal Vs Base Metal Question Table 4.1
- - By eekpod (****) Date 03-24-2009 17:52
I am preparing to run a new PQR plate using Base Metal M270 Grade 50 Type 2 SAW process.
Per Table 4.1 (pg 77) my SAW Electrode Specification should be AWS A5.17.
Question Can I use a SAW filler metal that is per AWS A5.23 with this base metal?
I think the answer is no, I'm limited to AWS A5.17 for grade 50, and AWS A5.23 shall be used for base metal HPS 485W.  But if I am qualifiying the procedure why can't I mix and match as needed.
Thanks Chris
Parent - By HgTX (***) Date 03-26-2009 18:58
Huh?  Read two lines further down in that same box; it gives you A5.23.
Hg
