Personally, any test I ever took seldom required more than the slag hammer. If you had to hit it more than once every couple inches to pop the slag off then things are not right in 'Weldingland'. The root may take a little more sometimes with the slag hammer. And the cap got a good wire brushing. Very little with the brush in between. No major labor effort to make it look like it was sanded to a shiny finish just to add more weld. If you can see it clearly, it is clean enough.
I've seen guys carry little screwdrivers, picks, files, all sorts of 'special' cleaning tools. Should not be needed.
I ran one the other day just to show my son it can be done, have you ever run a vertical groove weld uphill, 1/8" 7018, add new rod fast enough and everthing set right so the slag just curls up behind you as you go? No slag hammer needed. Had a curl going that was about 12" long before it popped from it's own weight.
This just to show, if settings are right, very little is needed to clean the weld. When testing, and on certain code jobs, the welds get cleaned with rod changes and between passes. Let it cool a little before hitting it with the hammer. It will pull itself loose to a degree as it cools. Proper settings and arc manipulation are critical.
Have a Great Day, Brent
I've made plenty of welds where the slag just falls off. This test is a 1" plate with 60 deg bevel, 3/16 gap, and 3/8 backing. 5/32 rod only. The coupons are RT, guided bend, then further examined at the state office in Austin. The root pass is the only pass that concerns me because it is tight with the 5/32. I'm not taking the test anytime soon but hope to do so this year. I have time to practice. If I'm going to drop close to a grand for this cert then it doesn't hurt to have a "special tool" on hand just in case I wake up on the wrong side of "Weldingland" come test day. The testing company said any hand tool can be used, so it's better to come prepared just in case. Sorry if I seem to have the red a**, just trying to be the best at what I do.
JohnJohn
John, Your post was not taken negative by me. And I understand, especially when taking a test you have never taken before, you are doing the prudent thing. Find out all you can, have ALL the tools allowed available to you just in case, and as I stated above, because it is a test clean everything and leave nothing to chance.
After you have done it and welded within that code's restrictions for a while, you will be more comfortable and know what YOU are capable of doing and how little you will need to do to still be successful.
Good Luck, Have a Great Day, Brent And Keep Us Informed.
"just trying to be the best at what I do"---quote
Nothing at all wrong with that, that's why I love to see people ask those types of questions. Best of Luck on test day :-)
