Hey guys, I have to cut and bevel 8" sch40 steel pipe , the problem is my space is very limited probably 5-6". I have seen the band type beveler's with a torch that runs parallel the pipe you are cutting and you adj. the angle of the cut with the torch head. Has anyone else seen this and if so do you know the manufacturer. Thanks Ed
