Hi all,
I am going to have a series of questions about welding 8" sch10 316L SS.
First question: how would you joint prep to produce a CJP weld? What I have done is use a slight v-groove, butt up tight, purge then fuse (autogenous) first pass at about 90 amps. Second pass (cover) is at about 75-80 amps with 3?32" 316L filler.
1/8",2% thoriated, 25/CFH.
Thanks,
Scott
