By swnorris
Date 09-29-2009 17:00
Edited 09-29-2009 17:04
Jason,
As trivial as it may seem, I agree with you that you should get an engineers approval. Intermittent fillet welds are typically for connections that don't require the strength of a continuous fillet weld, but in some cases, there must be some degree of calculation performed to determine whether intermittent welds will support the load. An example would be staggered intermittent welds joining a plate to the bottom flange of a beam that is to be used as a lintel. We don't know what's going through an engineer's mind, but if he/she calculates the required strength based on the staggered intermittent welds being symmetrically spaced on both sides of the joint, and the joint ends up welded differently, there may be problems. I don't know what the service application of your aluminum weldment is, but if I were you, I'd get approval, just to C.Y.A., as I believe that sometimes there's more to it than just to minimize distortion and to save labor.
