Hello Chevytown!!!
Just a tip about posting a website...
Make sure that when you type in the website, always start with:
http:// then type in for example: www.fungusworks.com/TheShow/index.html
In stead write it like this:
http://www.fungusworks.com/TheShow/index.html
The reason is because, in the forum it takes longer to come back to it if the person has to go back to their web browser, and then to BBS Grand Central...
Anywho, how are things in Califas otherwise known as California, besides the terminator running for governor?
Are you learning more about your equipment?
How are your welds coming out now that you've had some time to experiment with your settings?
Look foward to reading more!!!
Dios te bendigas caballero!!! (god bless you cowboy or horserider)
P.S. Btw, nice pics!! welds are a little rough but, with practice you'll definitely come up with nicer looking welds that have more uniform fusion, penetration, and overall better looking appearance... However, for someone who's just starting out, you are doing very well so, do'nt misunderstand my critique... Muy Bueno!!! Keep it up!!!
In your welding machine manual you have your voltage equivalents for your front panel settings, right? Does the same goes for your wire feed speed settings? Also, your gas shielding flow rates? If they are, please either post them or e-mail them to me so that I and others can give you suggestions for optimal welding machine settings so that your welds can come out better, Okay?
Holler!!!
