My favorite shield was one of those short shields we used to get from Electric Boat while working there...
Those hoods were so darn light and small enough to stick your head in some rather tight spots that you couldn't attempt with a regular shield, and were also great for pipe welding in between racks where there was limited access inside the subs especially in the engine rooms and working within the confines of the reactor compartment as well as some locations found in the torpedo room also. They weren't made of the different types of plastic or a combination of fiberglass and some polymers...
They were actually made of a paper type material that was coated with some sort of resin or chemical that really was good at not absorbing the UV rays from the arc even though the thickness of the material was very thin, the rigidity more than made up for it and that was possible also because of the resin like compound that was used on the paper as well. They had a standard head band which was probably heavier than the hood itself including the lenses that were attached to the shield.
The only down side to this shield was the obvious fact that protection was not as adequate when compared to a full size shield but, you could get into locations where a full size shield would never fit! I would pop rivet a piece of leather in front of the shield on the bottom lip for neck protection and piece of pigskin leather on the top lip of the hood for protection from spatter falling on my head and hair as well as my ears.
Back then,the A.O. Cool blues were popular and we used them along with some gold plated "True blues" which were just coming out in those days.. I also had one for some low amp Mirror TIG (GTAW) welding where we would use a rose colored lense that's commonly used in steel mills to look at the liquid as it's being poured out of the giant ladles which worked really well for certain applications where the light was very restricted in the locations where we found ourselves in sometimes, and you knew ahead of time that the job would require that maybe 60 amps tops was needed to complete the job, so these lenses were ideal to work with under those conditions.
I know that there some folks in here that know which shield I'm talking about because they used them also and if you do, where could I possibly buy one of those because I've tried locating one of those @ one of the local welding supply stores around my area with no success. I haven't looked enough online but, if anyone has a lead, please let me know because those shields were so comfortable to use! ;) ;) ;)
