"for GTAW it's useful for aluminum and also as a "trick" when welding low melt point metals such as copper to limit the molten puddle temperature for a given current. We would often run copper AC or DC reverse polarity to help lower the temp. "
This makes no sense to me. First, copper has such a high thermal conductivity, you need higher current than steels to form a puddle, so unless the cleaning action of AC works on copper and is beneficial, I see no logic in using AC or DCEP on copper. Second, the temperature of the molten puddle is largely limited by the melting point of the material, and using AC or DCEP is not going to change that. If you want less heat input to the puddle, instead of using a "trick" or AC or DCEP, just reduce the DCEN current.
