20mm = .787 inches
15mm = .591 inches
5mm = .197 inches
A simple program for performing a variety of conversions can be found here:
http://wscope.com/convert.htmBefore I begin I strongly suggest you get professional help or education. This fundamental lack of knowledge will be expensive for you and your company and might get someone killed.
There are many people here that will help you set up your program for a small fee.
You can sign up for a class in Houston, TX on February 22-24 here:
http://catalog.asme.org/Education/ShortCourse/BPV_Code_Section_IX_Welding.cfm?ProgramNumber=SC3607&CFNoCache=TRUEThe cost is about $1600 American, figure on an additional $1000 for the hotel and at least $200 for meals while you are there. WORTH EVERY DOLLAR
There is a program developed by one of the members of the Section IX committee that takes a lot of the guesswork out of WPQ/WPS writing:
http://www.cspec.com/Welder A+Welder B qualified range? QW-452.1 (b) Make sure you look at notes 1-3
Welder A qualified range? QW-452.1 (b) Make sure you look at notes 1-3
If we have 50mm plate to weld, can we use this welder A deposit 20mm+welder B deposit 10mm+welder A deposit 20mm? - Yes, QW-452.1 (b) welder A is qualified for unlimited as long as there are more than 3 layers of weld metal, you do not need welder B.
Maximum to be welded(means:weld metal thickness is Unlimited?) - The welder is limited to the maximum listed on your weld procedure (WPS)
Again,
