The reason that this doesn't work is that your Linde machine is a constant current stick machine. The 22-A feeder requires constant voltage to operate. In order for your feeder to work, you will need a constant voltage (CV) powersource. There are feeders on the market, usually called suitcase feeders (i.e. lincoln LN-25, Miller S-32P, 8VS and 12VS, etc.....)that will run on any machine, but unortunately, yours doesn't. If you would like to know the difference between the two, reply here and I will post another story.
Regards
