Up Topic American Welding Society Services / Technical Standards & Publications / Non-detailed splices?
- - By supermoto (***) Date 02-16-2010 14:37
Does anyone know where it is stated in D1.1 or AISC that if you have a non-detailed splice on a beam or anyother piece does it have to be welded.
Example:
There is some bent plate or tubing that is too long to come in a single piece and so multiple pieces are used to make up the length needed for that beam.  Typically the item has an intermitten weld that attaches it to the beam.  We typically just make sure that where ever the layout of the intermitten weld falls it has to be stitched at the splice.  Does this splice need to be welded and/or ground, if so what type of weld is required?  if it some bent plate that is maybe holding concrete or brick than we usally weld it on one side, but usually don't weld it both sides and don't grind it either.
hopefully this makes sense
Parent - - By 803056 (*****) Date 02-16-2010 15:39 Edited 02-16-2010 16:02
The EOR has a responsibility to review the detailed fabrication drawings to ensure the structural integrity is not degradated by the connections or slices joining members together. This principle as underscored after the walkway collapse at the Hyatt Regency in Kansas City.
The following excerpt is taken from a webpage I found on the subject.
ENGINEERING ETHICS
The Kansas City Hyatt Regency Walkways Collapse
Department of Philosophy and Department of Mechanical Engineering
Texas A&M University
NSF Grant Number DIR-9012252
Negligence And The Professional "Debate" Over Responsibility For Design
Instructor's Guide - Introduction To The Case
On July 17, 1981, the Hyatt Regency Hotel in Kansas City, Missouri, held a videotaped tea-dance party in their atrium lobby. With many party-goers standing and dancing on the suspended walkways, connections supporting the ceiling rods that held up the second and fourth-floor walkways across the atrium failed, and both walkways collapsed onto the crowded first-floor atrium below. The fourth-floor walkway collapsed onto the second-floor walkway, while the offset third-floor walkway remained intact. As the United States' most devastating structural failure, in terms of loss of life and injuries, the Kansas City Hyatt Regency walkways collapse left 114 dead and in excess of 200 injured. In addition, millions of dollars in costs resulted from the collapse, and thousands of lives were adversely affected.
The hotel had only been in operation for approximately one year at the time of the walkways collapse, and the ensuing investigation of the accident revealed some unsettling facts:
During January and February, 1979, the design of the hanger rod connections was changed in a series of events and disputed communications between the fabricator (Havens Steel Company) and the engineering design team (G.C.E. International, Inc., a professional engineering firm). The fabricator changed the design from a one-rod to a two-rod system to simplify the assembly task, doubling the load on the connector, which ultimately resulted in the walkways collapse.1
The fabricator, in sworn testimony before the administrative judicial hearings after the accident, claimed that his company (Havens) telephoned the engineering firm (G.C.E.) for change approval. G.C.E. denied ever receiving such a call from Havens.2
On October 14, 1979 (more than one year before the walkways collapsed), while the hotel was still under construction, more than 2700 square feet of the atrium roof collapsed because one of the roof connections at the north end of the atrium failed.3 In testimony, G.C.E. stated that on three separate occasions they requested on-site project representation during the construction phase; however, these requests were not acted on by the owner (Crown Center Redevelopment Corporation), due to additional costs of providing on-site inspection.4
Even as originally designed, the walkways were barely capable of holding up the expected load, and would have failed to meet the requirements of the Kansas City Building Code.5
Due to evidence supplied at the Hearings, a number of principals involved lost their engineering licenses, a number of firms went bankrupt, and many expensive legal suits were settled out of court. The case serves as an excellent example of the importance of meeting professional responsibilities, and what the consequences are for professionals who fail to meet those responsibilities. This case is particularly serviceable for use in structural design, statics and materials classes, although it is also useful as a general overview of consequences for professional actions. The Hyatt Regency Walkways Collapse provides a vivid example of the importance of accuracy and detail in engineering design and shop drawings (particularly regarding revisions), and the costly consequences of negligence in this realm.
The fabricator has a part to play, obviously a very important part to play, in the construction of a steel framed structure. If and when a member is not continuous due to construction constrains that were not apparent to the structural engineer, i.e., the EOR, the fabricator has a responsibility to let the EOR know of the condition and to obtain approval for any changes, deviations, etc. that are a departure from the structural design drawing. The inspector also has an important part in the orchestrated chaos. He should inform the EOR of any nonconformances or changes to the structural design that are not signed off (approved) by he EOR by means of stamped revisions, sketches, etc. Only those changes approved by the EOR should be permitted and accepted by the inspector, whether he works for the fabricator or the owner as a TPI.
It is not the inspector's responsibility, or the TPI agency, to approve changes made by the fabricator. In the context of construction here in the United States, only the EOR has the authority to approve changes to the structural design. I have been called in on jobs where the inspector or his employer, who had a P.E. on staff, approved changes that the EOR was not aware of. In one case, that TPI agency is no longer in business.
The direct response to your inquiry is that the question should be directed to the EOR. It is not a decision the inspector should be making. Any splice in the main member or attachments should be shown on the detailed drawing that has been reviewed and approved by the EOR.
I have seen designs that used the bent plates to increase the moment of inertia for bending loads. I've been on other projects were the bent plates carried only the masonry and were not considered in sizing the beam.  In the first case the butt joints in bent plate had to have complete joint penetration groove welds and in the second case the butt joints were simple intermitent welds. In each case the detail was reviewed and approved by the EOR.
Parent - - By supermoto (***) Date 02-16-2010 19:29
Very informative, thanks.
Parent - - By trapdoor (**) Date 02-16-2010 20:20
I agree. Make it like the print or get engineer approval. No matter how insignificant it may seem. That's how I operate and some people may not like it but it helps me get a good nights rest.
Parent - - By eekpod (****) Date 02-16-2010 20:58
We show splices on our shop drawings when they are sent for approval, this way they know that this is multiple pieces and that it must be spliced.  I'm thinking about bent plate mainly here, because if you have a 30' beam requiring bent plate welded on (stitch of course) that you won't find a sher and brake that can make that in one piece.  So you show the splices and put a weld there at the joint, normally a butt weld one or both sides, and some extra length stiches at the splice and its notmally not a problem.
I talked to AISC and they don't consider the bent plate as "structural" it's basically a pour stop for concrete and once the concrete hardens to plate doesn't do much.
Now it you had to put a splice in something other than bent plate, always make it pull penetration, unless a partial pen. is approved.
Chris
Parent - By swnorris (****) Date 02-19-2010 03:16
supermoto,
In addition to the intermittent welds attaching the pour stop to the beam, we center a 4" weld at the splice on both sides and we splice the pour stop directly to the beam flange (we don't splice the pour stop together and then add to the beam flange)
When splicing pour stop to pour stop, welding locations will depend on the leg lengths, the pour stop thickness, and the amount of overhang.
