Up Topic Sections / Section 39: Colorado / pipe welding resume
- - By LongArc (**) Date 02-22-2010 03:50
I'm a pipe welder with 26 months of documented experience. 3 years of welding on pressure vessels before that. I'm a single hand. I can fit and weld pipe. I've been on about 15-20 different job sites. All welding related. Is there a template for the trades to use? Most resume templates I've seen are made more for the white collar worker. Where can I go to see examples to pipe welding resumes...Thanks
Parent - By waccobird (****) Date 02-22-2010 09:52
LongArc
A resume is a resume, just make sure it isn't too long and contains pertinent information for the trade applying for.
If you are desiring out of country employment you will need traveling papers, passport...
But it could go like this.
CONTACT INFORMATION:
EDUCATION & QUALIFICATIONS
CURRENT CODINGS
EMPLOYMENT HISTORY
HOBBIES
REFERENCES
Good Luck
Marshall
