Up Topic Welding Industry / General Welding Discussion / saddle patterns, for making rails on stairs
- - By JE JACOBSS (*) Date 02-23-2010 05:09
any body know of any body that makes these pattersn? place i work for can never make up there mind, some times they want 38 deg on stairs sometimes 40 deg and today it was 45deg the 45 deg is not to bad its them odd angles, tired of cutting till its right, and my dumb ass never makes a pattern when i do get the right cut LOL. any help will be greatly apprectiated
thanks
Parent - By Cumminsguy71 (*****) Date 02-23-2010 17:57
What are you cutting out exactly? Are you talking round tube for hand/guard rail on stairs? I've seen some at Tractor supply, the steel ones but they really like them $$$$. I have bought some stuff from these guys, R.E. Lee Co. and was happy with their service, here's a link.
http://www.releeco.com/product.php
Not sure if that is what your looking for though. Here are some other links from a yahoo search.
http://www.onestepllc.com/
http://www.pipefitter.com/dolphincart/category.php?cat=Cat0027&page=4
http://yhst-11546588412052.stores.yahoo.net/
http://search.yahoo.com/search?p=Pipe+Saddle+Templates&toggle=1&cop=mss&ei=UTF-8&fr=yfp-t-701
Parent - By Dave Cook Date 03-19-2010 04:52
Check out 'www.pipesaddlelayout.com.  There is a page where you can enter in you pipe OD, ID, Ell Angle and have information to make a 16-division layout (or 64-division layout in the case of something like a 30" pipe template).  There are also pages for mitered ells, replacement industrial v-belt calculator, and other information. Hope this helps.
DNC
- By crahner (**) Date 02-23-2010 18:52
I have used all of the wrap around templates for torches and whenever possible I use the saddle jig for the chop saw.  It is faster and cleaner.  It gives more versitility for things like handrails when the saddles are not square.  It only takes one template to cut from 1/2 to 4 inch saddles.
I am on my third one and they are the best investment i have made in a long time.
http://uswelder.com/store/ArcherAccessories.html
ATCSJ2200C - PIPE SADDLE
- - By sailor Date 02-23-2010 22:42
Google. metal geek and go to coping calulater, it'll give you free paterns to copy on your printer. I then transfer them to vinyl fabric
Parent - - By JE JACOBSS (*) Date 02-24-2010 04:15
thanks for the help guys!!!! i wasnt to clear on my post, what i meant is if you making rails for steps that come down at a 45 deg angle your angle on the top rail is like 135 deg. wich would be two 67.5 degree cuts, that would make your rail come down at a 45, theres times they want the steps coming down at a 40 deg or 38 deg, i was just wondering if there were saddle patterns for all of them angles. and yes its using 1 1/2 or 2 in pipe.
Parent - By mooseye (**) Date 02-25-2010 00:54
I think you might be misunderstanding the reason for the different angle on the stair rails.
There is not a set degree of pitch for stairs. The pitch is determined by the rise and run of the steps. Given no space restrictions, you could make all steps come out to a certain degree of pitch but you would have to vary the tread depth in order to do so. Tread depth is something that does have a general set dimension, usually 10 inches.
Never the less, I usually just lay a speed square on the pipe and mark the angle desired and cut with a porta-band saw.
Good luck too you.
