I'm using a set I bought in "94", still in good shape. Have an older set, not sure when I bought them. And I have a new set, 4 or 5 yrs old. Use them for extension if needed. Only been used a couple of times though. I always outfit them with quick connects on the torch so I can lock it up in the cab of the truck.
Dave, if you got that set upon graduation, assumption High School, you were probably about "18" + 33yrs ago= "51" yrs of age. I looked at your profile, but didn't see when your birthday is. Anyway I figured you were younger than that. Your almost up there with me.
When I first went to work in the model shop in "83" the oxy/acy hose was burned up, cut over, repaired with duct tape, the whole spill. Worst hoses you ever saw. I would cut with it and almost everytime a flame would start up out of a cut or leak on the acy side. Constantly leaking, old worn out regulators, and a torch that had seen better days. You would think I was asking for eye teeth when I asked for a new set. The boss just whined and cried because the welder before me didn't have a problem with them. Probably because he didn't do anything to cause a fire. Anyway a serious safety violation and I had to mention that in order to get all new stuff. What about $400.00 for torch, hose and regulator. Heck of a lot cheaper than a hospital stay. Anyway some bosses are just too ignorant to do anything else I guess.
That's my gripe of the day.
Steve
