All y6ou need to do is to:
K.I.S.S... Meaning KEEP IT SIMPLE BLANK (one can use whatever they want to represent the last letter)!!! :) :) :)Focus on one book only!!!
It's a phony/imaginary code in a phony/imaginary code book!!! So focus on what you find in the phony/imaginary code book regarding how to inspect the samples because if you are still going by the same requirements/acceptance criteria found in the code book you picked for your open book test, then you are setting yourself up for almost guaranteed failure in that part "B" of the exam!!! :( :( :(
So Keep it simple, and focus only on the phony/imaginary part b code book and ALL OF IT'S INSTRUCTIONS regarding the requirements, procedures and acceptance criteria found only in the part B phony/imaginary code book and you'll do fine - CAPECHE??? Good luck and happy hunting next time!!! :) :) :)
Remember!!! Concentrate, and focus on studying, and using the Part B book only in order to successfully complete that part of the exam, and in order to avoid confusion on inspecting to the part b code book as opposed to AWS D1.1 or any other of the allowable codes that one can use for the open book test part of the CWI exam because;
THIS IS NOT THE OPEN BOOK TEST USING AN ACTUAL CODE THAT IS USED IN THE FIELD OR SHOPS!!!;) It is intentionally designed to trick you if you are not focusing on the code you are working to in order to test you on whether or not you can perform your inspection duties regardless of which code you are working from - PERIOD!!! ;)
Finally, practice if you have time in going from the open book test part of the exam and then switch to the part B phony/imaginary code book part of the exam and see how well you can change your focus from one code to another before you take the actual retest on part b because it will give you an idea if you can shift gears on the fly so to speak!!! ;)
I apologize if I'm a bit blunt, but I don't like to sugar coat important stuff unless it's absolutely necessary and it's not in this case here. ;)
