By aevald
Date 07-08-2010 01:43
Edited 07-08-2010 03:01
Hello tigrooter, there is a Miller RC and VS suitcase feeder, the RC uses the 14-pin Miller connection to operate in conjunction with the Miller CV output on their newer engine drives with 14 pin hook-ups and they will also run from any of the shop type CV machines with the 14-pin connections, the VS's will connect to any machine with CC or CV output. Ideally you should be run with CV if at all possible. There is plenty more that could be discussed in this light, but you have the basics here. Best regards, Allan
