Up Topic American Welding Society Services / Technical Standards & Publications / CJP or PJP?
- - By Nalla (***) Date 07-09-2010 11:31
Dear Friends
Pls review and advise
Also. is it  a single-bevel with 45 deg. become automatically must full-penetration weld?
Thanks
Attachment: CJPorPJP.pdf (35k)
Parent - By jrw159 (*****) Date 07-09-2010 12:49
Nalla,
  Yes, single bevel with 45 degree CJP. Fillet weld on the other side.
jrw159
Parent - By CHGuilford (****) Date 07-13-2010 16:21
If you can, you should check with the designer/engineer to see what the intent is.
That joint detail is often used where a fillet might be  specified,  but it becomes a groove configuration because of the plate angle.
You really don't want to backgouge that root if you don't have to - so it might be that partial joint penetration was actually intended but not shown.
