Us '4' and N'0' more.
Have a Great Day, Brent
How about SEVEN of these Larry!!! :) :) :) Next time I catch some fish worth posting, I'll do so but in the meantime, all I have to post for now are these
"MAGNIFICENT SEVEN"Respectfully,
Eight is enough! Enough already! (And please do not ask Lawrence if you can sub UT for RT again, ever...thank you.)
Does anyone here understand that the American Welding Society has ruined the trade? Look at every job search engine on the internet.. I challenge you to find a dozen in the entire nation that offer more than 18 bucks an hour. Maybe you can do it, but my point is valid. It has merit. I told you guys a decade ago what was happening and I was laughed at. The AWS has gone from a standard for welders and companies, to a multi million dollar industry in just 10 years. They will dispute this, but do the research. The actual standard for welding has completely turned into a Chinese type business. American is just a word now. I told you.
shrapnelblizzard@gmail.com.
I'll find you and kill you if you send spam. I have nothing left to lose. Hello Tommy.
You OK there buddy?
jrw159
By qa1
Date 05-14-2019 15:51
Should we CWI in order to get AISC bridge and FCM certification?
I want to qualify welders for FCAW. There are two options for welder qualifications, either bend test or radiography. Does the Radiography test is mandatory or Ultrasonic test can be done in place of Radiography ?
No matter how many times you ask
No matter how many different places you post the question
No matter how many forums you go to
The answer for D1.1 performance qualification is no. UT cannot be done in place of RT. No
No
No
No
Thank you for your reply. Intention was not to ask to many people, but thought if it is not posted in appropriate group, i may not get answer. Sorry for inconvenience.
hi
Which group of base metals can be welded together?
By Edaloy
Date 10-31-2019 12:21
Im Having a hard time finding a local CWI for contract and welder qualification work in Orlando area thanks
Hi Gents,
We have a partial penetration (S=21mm) with 5 mm leg length joint configuration ; (Tee Joint - combination weld (partial pen + fillet weld)
As per Client requirements if reference thickness is more than 25mm NDT should performed after 48 hours. (Reference thickness is
Could you please advise in our case what is the reference thickess 21 or 26 mm (21mm+5mm)
Ilkin Hasanov.
Two things;
Please do not post your inquiry in multiple places;
Please do not post your inquiry as a response to an older thread that has nothing to do with your question.
See my response in the other thread.
AHP Analysis - Fabrication SWH
This analysis aims to determine the Standard Work Hours (SWH) by evaluating the criteria: Labor Efficiency (LE), Overall Efficiency (OE), Job Weight (JW), Weld Volume (WV), and Skill Level (SL)
Please give your expert opinion in following link
https://forms.office.com/r/UqZQFSdpv0
