Up Topic Welding Industry / General Welding Discussion / P-20 Mold filler metal
- - By cmansonite (*) Date 11-07-2003 18:41
I sometimes find it neccesary to tig-weld-repair steel (P-20) molds in our shop on occasion. Our supplier recommends using Oerlikon OECRM01 for this mat'l and some stringent Pre/post heat requirements because of the need for these repairs to be invisible after a high polish (color match and stress relieve required) My distributor has no idea where to get this stuff and doesn't carry any U.S. product similar (I believe it is a chrome moly ER 80-s_?). Anybody know where to get this Tig rod, what its' exact specs are or where to get another version of it in the states? I tried their web site, but could only locate distributors in the U.K. and beyond. Thanks to all you knowledgable folks out there in advance.
Parent - By GRoberts (***) Date 11-08-2003 00:56
You might be referring to Oerlikon Carborod CrMo-1. It looks like the European version of ER80S-B2. You can find info on it at http://www.oerlikonweld.com/. However, it doesn't look like that close of a match to P-20 steel. The follwoing links might be helpful to you as they give some welding recommendations.
http://www.bucorp.com/Products/MoldMaterials/DataSheets/p20_modified.pdf
http://www.bucorp.com/pdfs/UddeholmWeldingofToolSteel.pdf
Parent - By brande (***) Date 11-09-2003 07:57
P20 is not a hard find.
Call Natweld, 800-433-3454. They will get you what you need.
Good Luck
brande
Parent - By cmansonite (*) Date 11-09-2003 17:08
Thanks for the links and the info.
Great stuff.
