Based on the info that was obtained courtesy of or from the American Society of Mechanical Engineer (ASME) (i.e. one of their welding articles that was for the welding of the Alloy 20-Cb-3), they have provided their recommended guidelines with respect to welding of this type of stainless steel alloy (that is pretty close to and resembling the "Alloy 20" type of stainless steel) where the SMAW process is use, as follows: "(1) Use of the welding filler material type that was developed for welding of this material (i.e. types E320LR and ER320LR of AWS A5.4 and AWS A5.9, respectively), (2) Keep the heat input to an absolute minimum (i.e. recommended welding currents for the SMAW process should be only 80% of that typically employed for carbon steels), (3) Maintain a short arc length (i.e. this also will result in reducing heat input to the weld), (4) Maintain an interpass temperature of less than 200 degrees F, (5) In order to avoid crater cracks, filling of the crater at termination of welding and washing back across previously deposited weld metal and (6) Where possible, keep the maintain the base metal restraint to a minimum. For welding for which the GTAW process is used, as follows: (1) Adjust welding current to achieve proper penetration at a travel speed of approximately 6 to 12 inches per minute, (2) On thin material, strike the arc on a carbon steel block or weld fixture and jump the arc to the start of the joint. On thick material, start the arc in the groove on the side wall. Do not start the arc on the material outside of the weld zone., (3) Avoid crater cracks by reducing the size of the weld pool before breaking the arc, either by increasing travel speed or by reducing weld current to very low levels, (4) Use filler metal when weld reinforcement is required, where fit-up is poor and at the end of joints, (5) Keep the arc length short to help maintain a low heat input and prevent atmospheric contamination of the shielding gas. Do not hold the torch at too acute (sharp) an angle, because this can aspirate air into the shielding gas stream and (6) Use gas backup (purge) wherever possible. This helps to prevent oxidation of the root side of the weld which lead to loss of corrosion resistance."
