Al, thanks for your reply.
I was looking at Figure 4.12 becasue its for a test specimen for pipe greater than 2", but that figure does not give a length, I see where you referenced Figure 4.10 that shows a length of 10" total.
Would'nt it have been easier if they just put a length in figure 4.12? Rather than have to use the referance of section 4.6.6.1 to tie these both together?
Thanks for the info BTW
Chris
FYI- No these are structural applications, the only thing going through these pipes is purge gas, and air once they are installed, these are not carryone fluid or pressure.
