Hey 65, I have the Weldtron remote for my 69. Got the finger tip controler with it. Haven't tiged with it but the finger tip works great when I have no one to run my heat for me when stick welding. The machine doesn't know the differance between stick and tig.
First I take it you want to tig like pipe for field work? If so then a bottle of 100% argon,argon flowmeter,argon gas hose, air cooled tig torch with valve (weldcraft 17fv series), power cable (weldcraft 150 amp 25' rubber), power block adapter (use an empty 20 oz coke bottle for arc protection), tungsten, collets, gas lens, and cups. Now take your stinger and connect it to the negative terminal and ground to the positive. Connect the stinger to power block. Thats pretty much it. Just remember you have to turn the the argon on and off with the vavle on the torch before striking an arc.
