Al is right. FN is the chosen technology now. But even with FN there is considerable variation in results. The IIW ran a pile of round robin tests on labs for FN and found a very broad range of results.
A broad range of results in testing is OK(2-14, 2-16 could be fine depending upon the alloy, the wall thickness, the welding process). All you are tyring to verify is if the FN is high enough to minimize microfissuring and low enough to minimize sigma.
Some alloys are more sigma prone than others, for example 316 as opposed to 308 due to Mo.
And keep in mind that fully austenitic SS welds are made every day on alloys such as 310.
FN can be applied to filler metal and welds. Often you will see filler metal evaluation by diagram and weld evaluation by FN testing.
The problem with diagrams is that they don't account for cooling rate. The problem with FN testing is the inherent error of magnetic permeability testing.
