Joel,
Chew on these links & .pdf's for a while, and I'm sure you'll find something that will help your own specific application even though you give us practically nothing to work with for obviously good reasons...
These folks are known to solve problems... Pick their brains a little and see if I'm right:
http://www.pcc-york.com/index.php/militarygovernmentThese folks are good at what they do and I'm sure you already recognize some of them from you previous position.
http://www.pro-fusiononline.com/pdf/pwt-aug99.pdfhttp://www.pro-fusiononline.com/feedback/pwt-aug99.htmHere's a couple of articles which may be of interest to you:
http://www.arcmachines.com/industries-served/nuclear/plutonium-bearing-containershttp://sti.srs.gov/fulltext/ms2002053/ms2002053.pdfhttp://www.thefabricator.com/article/esab-welding--cutting-products/robotic-gtaw-or-gmaw-no-longer-a-clear-cut-choiceMore stuff:
http://www.ysxbcn.com/upfile/soft/20110402/06-p0467.pdfhttp://pii.sagepub.com/content/225/2/270.full.pdf+htmlMaterials Sciences and Applications, 2011, 2, 251-257
doi:10.4236/msa.2011.24032 Published Online April 2011 (http://www.scirp.org/journal/msa)
Copyright © 2011 SciRes. MSAProcess Parameters Optimization of an Aluminium Alloy with Pulsed Gas Tungsten Arc Welding (GTAW) Using Gas MixturesPawan Kumar1, Kishor Purushottamrao Kolhe2, Sashikant Janardan Morey3, Chanchal Kumar Datta1
1Department of Mechanical Engineering, Delhi College of Engineering, Delhi, India; 2 Department of Mechanical Engineering, Agricul-tural University, Ratnagiri, India; 3Department of Production Engineering, College of Engineering and Technology, Akola, India.
Email: {kishor_kolhe, ckd5929}@rediffmail.com, pks_munesh@yahoo.com
Received December 7th, 2010; revised February 1st, 2011; accepted March 4th, 2011.
ABSTRACT
This paper demonstrates the enhancement of mechanical properties and effective optimization of pulsed GTAW process parameters on aluminium alloy 6061 using sinusoidal AC wave with argon plus helium gas mixtures. Modified Taguchi Method (MTM) was employed to formulate experimental layout and to study effect of process parameter optimization on mechanical properties of the weld joints. Microstructural characterization of weld joint was carried out to under-stand the structural property correlation with process parameters. Keywords: Pulsed GTAW, Aluminium Alloy 6061, Gas Mixtures, Mechanical Properties, Modified Taguchi Method, Microstructures... Here's the link to the .pdf:
http://www.scirp.org/journal/PaperDownload.aspx?DOI=10.4236/msa.2011.24032These folks really know their stuff when it comes to Variable Polarity GTA pulse welding parameters... Why not pick their brains a bit???
http://www.liburdi.com/LiburdiAutomation/Pages/LTP400-VP.pdfhttp://www.liburdi.com/LiburdiAutomation/Pages/LT1000-HS.pdfhttp://www.liburdi.com/LiburdiDimetrics/Gold-Track-VI/White%20Papers/GTVIapplicationsBrochure.pdfhttp://www.liburdi.com/LiburdiDimetrics/Gold-Track-VP/White%20Papers/GTVP_datasheet.pdfHere's a very cool tool if I may so myself
http://www.liburdi.com/LiburdiDimetrics/MSIV/White%20Papers/MSIV_Liburdi_Votech.pdfHere's another one:
http://www.liburdi.com/LiburdiAutomation/Dabber/White%20Papers/Dabber_000.pdfMore articles:
http://neuron.tuke.sk/~vascak/predmety/FSR/Eseje/Muller%20-%20Fuzzy%20control%20of%20pulsed%20GTA%20welds%20by%20using%20real-time%20root%20bead%20image%20feedback.pdfCheck out these papers and see if they are of any interest to you:
http://traidia.free.fr/Check out this paper also:
http://www.comsol.com/papers/7901/Here's another good paper:
http://www.osti.gov/bridge/servlets/purl/919545-5GcnMB/919545.pdfMore food for thought:
http://sta.uwi.edu/eng/wije/vol3201-02_jan2010/documents/RootPassWelding.pdfThis is something that may not be directly useful to you yet it can be interesting nonetheless:
http://www.engr.uky.edu/~ymzhang/Papers/Wu%20Post%20Paper%204.pdfhttp://www.engr.uky.edu/~ymzhang/Papers/Wu%20Post%20Paper%203.pdfhttp://www.lhu.edu.tw/m/oaa/synthetic/publish/publish/20/1.%E8%94%A1%E7%93%8A%E6%98%9F-Model%20and%20control%20Pulse%20GTAW%20for%20steel%20pipes%20by%20Real%20time%20RBF%20neural%20networks.pdfAnd of course, we must not exclude our old eclectic friend - Ed Craig and his site which has some interesting nuggets of welding wisdom:
http://www.weldreality.com/tigData.htmThis one (I highly recommend), you need to go to the right of the screen and find the .pdf link which will then open up s small window towards the top... Then you need to click download and the .pdf will open in a separate web page .pdf:
http://www.jmst.org/EN/abstract/abstract7134.shtml#Another fun article although, not as good as the previous one:
http://mtf.tu-sofia.bg/mtm/lit/books-welding/RoboticWelding-II.pdfHere's an older article/paper or two:
http://ieeecss.org/CSM/library/1994/aug1994/02-AutomatedWelding.pdfhttp://lib.semi.ac.cn:8080/tsh/dzzy/wsqk/selected%20papers/welding%20journal/70-11-287s.pdfThis one I'm sure Professor Giovanni Crisi will be proud of:
http://www.jatm.com.br/papers/vol2_n2/JATMv2n2_p203-210_Advances_of_orbital_gas_tungsten_arc_welding_for_Brazilian_space_applications-experimental_setup.pdfAnother fun paper:
http://zurnalas.mechanika.ktu.lt/files/393-KahM173.pdfMore good stuff:
http://www.aws.org/wj/supplement/Ko02-01.pdfhttp://www.waset.org/journals/ijame/v5/v5-4-37.pdfThis will put you to sleep:
http://prr.hec.gov.pk/chapters/254S-2.pdfThis one is visually stimulating:
http://www.sut.ac.th/engineering/Metal/pdf/MetJoint/04_Weld%20microstructure01.pdfA fundamentally good article or two from Miller Electric:
http://www.millerwelds.com/resources/articles/Advanced-TIG-controls-greater-performance/http://www.millerwelds.com/resources/articles/TIG-GTAW-frequency-amplitude-balance-waveform-controls-inverter/http://www.millerwelds.com/resources/articles/Dynasty-200-Pulsed-TIG-GTAW-welding-exhaust/http://www.millerwelds.com/resources/articles/search/search-results.php?welding_application=&welding_category=5&welding_kbi=&tags=&submit=SearchThese are the last ones I'm posting since after all, This post has to end somehow:
http://smartweld.sourceforge.net/Tech_Disc2.htmhttp://www.ysxbcn.com/upfile/soft/2008928/2008928143017681.pdfhttp://sti.srs.gov/fulltext/ms2003085/ms2003085.htmlhttp://www.ijest.info/docs/IJEST10-02-05-04.pdfRespectfully,
