It took me a while to figure this one out but my phone has a camera in it.
After a bit of thought on how to show people work I have performed with out a lengthy explanation, I decided to make a portfolio by taking pics with my phone and saving them to my PC. Unfortunately this idea came to me a bit to late so my portfolio isn't all that extensive. But I did get it started at least. I will share some with you. Be warned some pics aren't as clear as I would like them to be.
My weld starts at the left of this pic being a 3/4" that ties down into a 1/2" and into someone else s weld on the right.
Another similar pic to the top but only my welding in this pic.
Working on an ammonia system at Patric Cudahy I walk into a room with more pepperoni than i had seen in all my life. This pic doesn't do the room justice its a very big and long room that has pepperoni on both sides packed full. Couldn't help it had to try to get a pic of it.
Fixing leaks on an ammonia coil until the new unit could be delivered and installed. This was at the end of the pepperoni room. I was the only guy who didn't have safety gear for a possible tragic accident should it have spewed out liquid ammonia.
This was a CNC conveyor that needed an engineering update to the frame after they found out it was folding the original frame design like a pretzel. It doesn't look like it but I did grind the paint off were I welded, but i had to trace around the parts and grind off only enough paint for welding. They were being very anal about it rusting despite the fact that it was getting painted over after I was finished.
An aluminum weld on a old leaking semi fuel tank. Cut me a little slack on this one, aluminum that has seen this many highway miles and has been leaked on that long is hard to weld despite efforts to clean the aluminum prior to welding.
Couldn't get a pic of the job, but its a trip to drive down an airport tarmac. You can see the crash fence I installed in the side rear view mirror tho.
A way old pic a guy took of me welding in custom made leaf spring hangers on a friends truck. He bought the truck brand new and this pic was taken 6 months later. The factory front end suspension wasn't cutting it for mudding.
Made this for the wife using a piece of 304l SS and a few mild steel scraps from the plasma table. This pic was used as an forum avatar for her. The original is hanging in our living room.
For anyone who wants it I set this pic up and edited it to work as a forum avatar. Feel free to use it by right clicking and save image. Forum avatars are set to a really small size here so IDK if it will work in these forums.
