Voltage about 17 ~ 18. Gas flow rate 20 CFH. What is the wire stickout past the contact tip/tube? ~ About 1/4 ~ 3/8 & using a push gun travel angle. I believe the arc control is inductance control I would set it at 50% or lower. Lower if the starts are "stumblying" higher if spatter is an issue.
