Are you repairing the frame? If so where at and what type of repair?
Are you stretching the frame? On Semi Tractor frames if it has been heat treated it usually has a sticker somewhere on the frame, usually yellow, say do not weld -heat treated material. I have before. Need to know your exact situation as much as possible.
Brian J. Maas
