I have the twelfth edition of The Procedure Handbook of Arc Welding from 1973, which was published by Lincoln. I don't know how much the technology or techniques for vertical down have changed over the last 30 years, because we don't do vertical down, except as permitted in D1.1. There were no procedures written in the Lincoln book for vertical down welding in the SMAW process, except for a few using E6010, 6011, 6012, and 6013 electrodes, and those were for a plate thickness range of 18-10 gage. Out of morbid curiosity, I checked the other welding processes in the book and found only one more procedure for vertical down, which was in the FCAW process using E70T-G on plate in the thickness range of 12 gage -1/4". I also looked through my “welding stuff” file and did manage to find the following information about vertical down that may be helpful: Vertical down welding is better suited for welding light gauge metal because the penetration is shallow and diminishes the possibility of burning through the metal. Furthermore, vertical down welding is faster than vertical up. The current used for welding upward on a vertical plate is slightly higher than the current used for welding downward on the same plate. To produce good welds, you must maintain the proper angle between the electrode and the base metal. In vertical down welding, incline the outer end of the electrode downward about 15 degrees from the horizontal while keeping the arc pointing upward toward the deposited molten metal. When vertical down welding requires a weave bead, you should oscillate the electrode. When using E7018 electrodes in the vertical down position, you should modify slightly from the vertical down procedure that use electrodes other than low hydrogen. When vertical down welding with low hydrogen electrodes, you should drag the electrode lightly using a very short arc. Refrain from using a long arc since the weld depends on the molten slag for shielding. Small weaves and stringer beads are preferred to wide weave passes. Use higher amperage with AC than with DC. Point the electrode straight into the joint and tip it forward only a few degrees in the direction of travel. Adjust the amperage in the lower level of the recommended range. I hope this helps you.
