Hi
This post is a little old, but thought you may still be interested in an answer.
I had a look, and see that the Coreshield 8 Ni has 1% Nickel. Typically the 1% Ni consumables are for obtaining better fracture toughness than the normal carbon steel fillers. The main mechanism for achieving this is that the weld metal has a finer grain structure due to the Nickel addition. Most of the time, for more critical structural welds, we tend to use the 1% Ni filler materials, although the one's we normally specify are the 80kSi fillers. Also, we (so far) never use the self shielded FCAW consumables, as they tend to produce lower quality weld deposits when compared to the gas assisted consumables. I notice that the Coreshield 8 Ni is a 70 kSi filler, so does actually not give the designer a higher strength to work with. I also see that the Carbon content is significantly lower in the Coreshield 8-Ni filler (0.03%) compared to the normal Coreshield 8 (0.17%) so while the Ni would typically add to the strength, this tendancy has been reduced by reducing the C content. Theoretically this should give an improved toughness, with comparable strength, with good resistance to forming martensitic microstructures that could lead to hydrogen cracking. I see that ESAB recommends this filler for root runs in constrained joints, so this all seems to make sense.
The H5 designation will have more to do with the flux than the Ni addition. Again, given that their market is for a filler to reduce the probability of hydrogen cracking as far as possible, this choice of flux makes sense.
It will be good to get some feedback regarding people's experience with self shielded FCAW these days. Have these wires improved enough to give deposits suitable for critical "primary steel" off-shore structures?
Hope this helps.
Regards
Niekie
Ladies and Gentlemen,
I have five patents in welding involving underwater welding / welding in damp environments. In the past the Lincoln Fleet Weld electrodes had a drop of nickel in them to achieve a surface tension / heat capacity benefit on the puddle and resulting weldment. This yielded smoother weldment. It is part of my welding consumables. Lincoln has used other ways to get the benefit than expensive nickel. I hope this is helpful
Sincerely
Len Andersen weld@spemail.org
914-536-7101 / 212-839-6599 8-4 New York Time , 4042 FAX , Co-worker 6381 / 914-237-7689 (H)
POB 1529 / NYC 10116-1529 ( $1180 per year Caller Box GPO NYC / Most Secure Service At Largest Post Office )
www.lenandersen.com
