Hi Hobart
Looking through some old posts, and saw that yours was not answered, so thought I would give it a go.
Generally speaking, the voltage is mostly a function of the arc length. Changes in current will change the voltage for a given arc length slightly, but not significantly. The current pulses in pulsed GTAW will therefore have little effect on the voltage, as the arc length remains constant.
Hope that helps.
Regards
Niekie
